× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Netgear nighthawk MR2100
Deewhy55
Follower
Hi
The router displays a red flashing light overnight when not in use. I restart the router in the morning. It sets up correctly with blue flashing light then after a short period the router reverts to red flashing light. No devices are connected at the time. I have reset the router and have the current updates loaded.
Message 1 of 3
Guru
Re: Netgear nighthawk MR2100
Netgear has set up a community forum specifically for the Mobile Router products. Most of the people who watch that forum are more likely to have experience with mobile routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
Thank you
Message 2 of 3
JohnPeng
NETGEAR Expert
Please follow the steps below to capture a model.json file with the SIM inserted. You can send the lg to me via privide messsage.
- Logon to the webui (http://192.168.1.1 ) as an administrator
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it back
Thanks
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 734 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
