Orbi WiFi 7 RBE973
Reply
Netgear nighthawk X6
jarengage
Follower
Need to update
Message 1 of 2
Guru
Re: Netgear nighthawk X6
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.well you can manually update:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
or try the automatic router.
https://kb.netgear.com/23442/How-do-I-update-the-firmware-on-my-NETGEAR-router-with-a-web-browser
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 444 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
