- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear nighthawk
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Netgear nighthawk
My modem download speed is 245mbs but my nighthawk router is only 143mbs. Is there any way to improve this??
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Netgear nighthawk
1. what modem are you using? make and model
2. firmware on your router?
3. how are you testing? wired/wireless? 2.4ghz/5ghz?
4. Are you testing with the build in app, using a pc browser, using the speedtest app ? be specific as different methods are going to give you different results
1.4gig download/50mbps upload
We’re members of the public helping out on our own time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
NETGEAR - Nighthawk AC1900
R7000-100NAS
I believe the most updated firmware but I can't check as I'm not home.
The test results came from the spetrum tech who came out to the house, he did ethnet to modem than to Nighthawk router and than check the coax connection outside, the slowest sppeds
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@Deductedsolid wrote:NETGEAR - Nighthawk AC1900
R7000-100NAS
This didn't make much sense. Plus trusting techs doesn't always turn out well.
1. what modem did they hookup?
2. when you get home, what firmware on R7000? when it comes to the r7000, the latest isn't always the best. its been known to have firmware issues with some of the newer versions
3. what speeds do you get hardwired into the modem? And hardwired into the R7000? Not the tech but you.
4. and how are you testing those speeds? I'd recommend using dslreports.com for speedtesting.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Ok thank you, I do all this when I get home and repost.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Firmware Version V1.0.9.88_10.2.88 this is the firmware. I have to wait a little to run speed tests, son is in an online class at the moment.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
When it comes to the R7000 the 2 best firmwares are either 1.0.9.42 or 1.0.11.100.
If you change firmwares on the R7000, the best (most succesful) router is to upgrade/downgrade over an ethernet connection, factory reset afterwards, and to manually install. it can be a bit of a pain but it tends to have the best results.
https://www.netgear.com/support/product/r7000.aspx
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thank you I have seen a improvement, I will keep an eye on it over the weekend when everybody is using it. You mentioned 2.4ghz/5ghz I have it set to smart detect would you advise this or not?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
smart connect depends on your usage. the average home user is going to do fine with it.
Something to keep in mind with it through is it has to "learn" your usage per device. So sometimes devices start out poorly on 2.4ghz until they get switched to 5ghz.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Things haven't really improved. I think it maybe the location of the router its in the master bedroom at the back of the house. Do you know of anyway to help boost the signal around the house?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
How big is the home?
What are your interior walls made of?
This are kind of critical as certain materials block wifi very well. And abover a certain size you might need different solutions.
One thing I would recommend is trying to centrally locate the router. Most routers are omni directional meaning the broadcast in all directions. If its on one side of the house, half its broadcast is into your yard/exterior walls.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
its 2800square ft. Not sure what the walls are made from. I'm not sure how I more my router because how will it connect to the modem. Thank you for your help on this matter.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
1. 2800sqft is fairly decent sized for a single device. Especiall if its not centrally located.
2. you can potentially move the modem and the router to centrally locate. Some homes have coax jacks in each room.
3. try knocking on your walls. If their brick, it'll be pretty solid. Same with plaster lathe/adobe. sheetrock/wood construction is going to be lighter and more hollow.
4. If you can't move it. A mesh extender might not be a bad idea. I'd recommend the triband extenders. I'd also recommend not using more than 1 extender. If you're needing more than 1 extender, an upgrade to a full mesh system like orbi is advised.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I will try moving but then how will I connect my wired connections that run from the master bedroom closet?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I'm not sure what to tell you. I don't know your layout, your wiring, what you've got going on and can run ethernet/coax.
I'm just saying, for best performance out of a single router solutions, centrally locating is best. You can add an extender if you want more range. But if you're needing more than 1 extender, you should be running a full mesh system like orbi.
