Reply
Netgear r6400 advanced options grayed out
ebraho
Follower
I just updated the firmware on my R6400 router and reset it to factory settings. Once I logged in with my new username and password, I wanted to setup remote management through advanced settings, but most options there are grayed out.
Anyone have any ideas?
Thank you!
Model: R6400|AC1750 Smart WiFi Router
Message 1 of 2
antinode
Guru
Re: Netgear r6400 advanced options grayed out
   Is that accurate?  R6400 or R6400v2?  Look for "Model" on the product
label.  Firmware version?  Connected to what?
> I just updated the firmware on my R6400 router [...]
   To what?
> [...] and reset it to factory settings. [...]
   And then what?  Did the freshly reset R6400[vX] configure itself as a
wireless access point (perhaps for some good reason)?
> [...] advanced settings, but most options there are grayed out. [...]
   "most"?  Which?  Here's a list of features which are disabled in a
router-as-WAP:
      https://kb.netgear.com/26765
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 335 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
