Reply
Netgear won't accept Nanostation Unifi?
Jochends
Follower
Hi all,
I am using 2 Nanostation M5 + 1 AP (TP-LINK ) to setup a connection between 2 buildings (+- 30m).
I can access both only when i manually put an UTP cable from the nanostation to my laptop and connect to their IP OR when i use another router as test.
I can't find or ping the nanostation on '192.168.0.10' or '192.168.0.11' when i connect them to my LAN switch.
I did the following
LAN switch( is working and connected to router also ) => LAN adapter
Nanostation AP => POE adapter.
Access Point ( TP-Link ) => LAN adapter
Nanostation STATION => POE adapter.
The LAN/POE adapter is the original adapter from Ubiquiti.
I tryed this while the 2 Nanostations are in range of 3m for testing.
The cables are fine and the switch is also on the same network ( only 1 network here ).
There is no IP-adress conflict with the netgear and the DHCP is
192.168.0.50
192.168.0.200
Gateway: 192.168.0.1
Tryed different DNS also
 Here are pictures of the settings which works fine on another router.
AP 1.JPGAP 2.JPGAP 3.JPGAP 4.JPGAP 5.JPGAP 6.JPGAP 7.JPGSTATION 1.JPGSTATION 2.JPGSTATION 3.JPGSTATION 4.JPGSTATION 5.JPGSTATION 6.JPGSTATION 7.JPG
Model: R7800|Nighthawk X4S AC2600 WiFi Router
Message 1 of 2
schumaku
Guru
Re: Netgear won't accept Nanostation Unifi?
"Netgear" == define, whatever "my switch" model or the tagged R7800 router GbE Ethernet port?
"2 Nanostation M5 + 1 AP (TP-LINK )" is this stuff configured as a PtmP or PtP bridge?
If configured as either a PtmP or PtPm you can't connect both to the same switch resp. the same switched/wired LAN.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1023 views
  • 0 kudos
  • 2 in conversation
Announcements
