Reply
Netgear
Tomsta79
Netgear
Netgear R7500 . keeps rebooting every now and then . so i updated firmware to newest one and reset router from the back . but its still rebooting by its self and i don't no why any help with this thanks
Model: R7500|Nighthawk X4 AC2350 Smart WiFi Router
Message 1 of 3
DarrenM
Sr. NETGEAR Moderator
Re: Netgear
Are you saying all the setting default back to stock or the unit powers off and comes back on and you just have to wait a couple minutes? If thats the case have you tried moving the power plug of the unit to another outlet?
DarrenM
Message 2 of 3
Tomsta79
Re: Netgear
hi there ive never tryed moving plug . plugs in extension at the min . it just reboots every now and then it keeps all my settings  then just connects again . checked plug this morning as i bought second hand and its a huawei power plug could it be down to that even if it was the right voltage . thanks for reply
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 254 views
  • 1 kudo
  • 2 in conversation
Announcements
