Reply
Network printer works on LAN but not wifi
Matyboy
Follower
I have a MR60 Nighhawk which connects to our LAN via a network router.
On the LAN we have a network printer and our laptops can print OK when nonnected via Ethernet, but if we connect our laptops via Wifi through the Netgear Nighhawk the laptops cant print, additional information:
  • when on wifi I can actually ping the printer ok so it can see it
  • have tried re installing printer drivers but no success
  • the LAN router has a seperate wifi we dont actually use so I connected to this and can print OK so it is isolated to the nighthawk only.
  • The Nigthawk is running firmware V1.0.6.102 which it says is the latest
Any help would be appreciated as I am ready to through out the Nighthawk as I cant find the setting that is doing this
Message 1 of 2
Guru
Re: Network printer works on LAN but not wifi
running 2 routers on a network can cause issues like you're seeing. its called a double nat. https://kb.netgear.com/30186/What-is-Double-NAT
What isp router do you have?
If you're not using it, try putting it in modem only/passthrough mode.
Current Setup: CM2000-> SXK30-> GS716v2-> RAXE500->
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 132 views
  • 0 kudos
  • 2 in conversation
Announcements
