Reply
New Nighthawk AC2300 Smart Wifi Router, Model 7000P
ANTLEESFS
I purchased the R7000P along with the C6220 router.  When ever I connect the C6220 router to the R7000P, I get a solid red/orange light with the message, no interenct connectivity. In addition to that, when I sat the C6220 next to the R7000P to ensure the CAT 6 line was not the issue; something between the two devices would not allow me to reconnect to the R7000P. Can someone please provide some insight? I am not tech savvy.
Model: R7000P|Nighthawk AC2300 Smart WiFi Router with MU-MIMO
Message 1 of 4
myersw
Master
Re: New Nighthawk AC2300 Smart Wifi Router, Model 7000P
The C6220 is a modem/router. Are you using it as a router as well as modem?
If so then the R7000P needs to be setup as an access point (AP) and not as a router.
See the user manual to see how that is done. Not hard.
--bill
--Bill
ISP Comcast, Modem-Netgear CM1150V, Router-Unifi Security Gateway-Pro4, AP-2 Unifi AP-LR
Tesla > Edison
Message 2 of 4
ANTLEESFS
1. The R7000P, services my HUE SMART BRIDGE, CAMERA SYSTEM and (?) the C6220.  I have a 250' CAT6E line that runs from the R7000P to my MAN CAVE.  I was attempting to use the C6220 as another direct gateway to my SMART TV, Fire Stick and Mobile Device when ou there.  Hopefully this explains my issue a bit more.
Message 3 of 4
antinode
Guru
> C6220.
   "services"?  I don't know what that means.  What, exactly, is
connected to what, exactly?  (Hint: If a device has multiple Ethernet
ports, then "connected to device" is not enough detail.)
> [...] I have a 250' CAT6E line that runs from the R7000P to my MAN
> CAVE. [...]
   Swell.  _What_ on "the R7000P" gets connected to _what_ in your "my
MAN CAVE"?
> [...] I was attempting to use the C6220 as another direct gateway to
   Try to resist explanations like "direct gateway", and concentrate on
what's connected to what.  The non-psychics in your audience have no
idea where all this equipment is situated.  Where are all these gizmos,
and what, exactly, are you trying to do with them.
> [...] Hopefully this explains my issue a bit more.
   "More" and "better" are spelled differently for a reason.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 630 views
  • 0 kudos
  • 3 in conversation
Announcements
