Orbi WiFi 7 RBE973
Reply
New Nighthawk issues
mgalbert
Follower
I have had a couple issues.  Any help?
1) I consistently get non stop Genie Timeline Agent errors (ding ding... cannot extinguish error flag)
2.) Firmware was showing as having a new version, however, newest version showing.
3) Ethernet port shows Amber light on on port, White on another.  (Both seem to work).
Any help would be appreciated.
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 2
Accepted Solutions
Re: New Nighthawk issues
Check here for the latest firmware:
>>> D7000 | Product | Support | NETGEAR <<<
But first read this:
Re: Nighthawk D7000 2.4Ghz WiFi issues - Page 11 - NETGEAR Communities
Maybe you have the D7000v2, in which case, read this:
Re: D7000v2 firmware update v1.0.0.45 will NOT ins... - Page 2 - NETGEAR Communities
The amber light means that it is connected to a device running at 100 Mbps. The green one runs at 1000Mbps.
Message 2 of 2
All Replies
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 707 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
