- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New R6700 V3 connected to old routers WiFi
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New R6700 V3 connected to old routers WiFi
> [...] I owned a R6700 V3 router and it got bricked. [...]
How did that happen?
> [...] I have been having more issues with it [...]
"more" than what? "issues"? Thanks for that detailed problem
description.
> [...] Is it because it connected to the old routers WiFi?
If you "sent it in", then your old router is gone, and nothing is
"connected" to it now. Unless you believe that there was something
magical about your old SSID and passphrase, then you might have some
kind of (unspecified) problem with the new router, but I doubt that
reusing your old wireless-network credentials would explain it (whatever
it might be).
If you had problems with your old R6700v3 (before you killed it),
then I would not be completely amazed if you had similar problems with
your new R6700v3 (until you kill it).
Firmware version(s)? Actual symptoms?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Power Outage during firmware update
Internet speeds slowing down and going down completely where I have to unplug the modem and router to reset my internet. I already talked to my internet provider and everything is working fine on their end.
Firmware is V1.0.4.102
Not sure why you’re being a D$@k to a complete stranger, but hope you get it figured out for your own sake. I’m new to this, sorry I didn’t know how to properly explain it over text.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That could do it. When it happens again after your warranty's gone,
there are recovery schemes which might help.
Not the latest. You might try a different version and/or the usual
last resort: a settings reset and manual reconfiguration.
Visit http://netgear.com/support , put in your model number, and look
for Downloads. (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".) Find the kit(s).
Download the kit(s) you want. Read the "Release Notes" file for
instructions. (In the User Manual, look for "firmware", and,
especially, for a topic like "Manually Upload Firmware to the Router".)
When that fails because of a deficient User Manual, try:
> Not sure why [...]
Not sure why you'd think that a problem description like "issues"
would do more than waste everyone's time. (Who's being a what?)
A forum search for "R6700v3" might find some relevant tales of woe.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Weaver909 wrote:
So I owned a R6700 V3 router and it got bricked. I sent it in for a replacement through my warranty. When I got the new Router I set it up like you would any new router. I ended up choosing to keep my WiFi name the same and then the new router automatically connected itself to the old network.
Good move. That works for most people. I do it all the time.
@Weaver909 wrote:
The internet works, but I have been having more issues with it ever since I got the new router. Is it because it connected to the old routers WiFi?
Not knowing what those "issues" are, it is hard to begin to guess what causes them, but using the same SSID and password – it isn't "the old router's wifi" – isn't likely to cause many problems, especially if they have nothing to do with wifi, if that is the case.
