Orbi WiFi 7 RBE973
Reply
New R7000P will not get to password prompt
JimmyW
Luminary
After I set up my router, I on to it to change the default password.  I entered the default password, but then I was aked to answer secret questions that I never chose before - default questions?  "What's your younger sister's name?" So I did a reset on the router.  Thereafter, Win 10 found the networks (low/high).  One network displayed Connected no Internet.  When I disconnected/connected, I never got past the checking connection window, and then nothing.  And I can't log in to the router, either.  So, what next?
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: New R7000P will not get to password prompt
You may want to check out this KB.
https://kb.netgear.com/978/Completely-avoiding-the-Smart-Wizard
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 416 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
