Reply
New to netgear
SaintJulio
New to netgear
Im planning to get a netgear and have a couple questions. Does Netgear need a modem to work or does it work as soon you connect the coax cable from the wall to the netgear will it work? Do you have to pay monthly like Xfinity for example? Im new to this and hopefully find an answer to this
Message 1 of 11
Accepted Solutions
Re: New to netgear
A Netgear what?
What is the "coax cable from the wall"? It may or may not need a  modem, depending on what sort of Internet you get.
Ask your ##Internet service provider what equipment you need. It may offer to rent of sell you something. But most will let you use your own equipment
Xfinity is an ISP. All ISPs that I know of charge for access.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 4 of 11
All Replies
microchip8
Master
Re: New to netgear
Yes, it needs a modem.
No, you don't have to pay monthly. It's your equipment.
Routing: NETGEAR RAX43 - Firmware: V1.0.11.112 (1 Gbps down, 50 Mbps up)
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400, 16 TB
Message 2 of 11
SaintJulio
Re: New to netgear
Thank you so much for replying
Mind if i ask where i can buy a modem?
Message 3 of 11
Re: New to netgear
A Netgear what?
Just another user.
Message 4 of 11
SaintJulio
Re: New to netgear
Thanks for writing back
I had xfinity but recently changed to fios but canceled there service not to long agoi
Netgear i was planning to get was ac1900 router
Message 5 of 11
Re: New to netgear
You'll have to sign up with someone to get onto the Internet. I'd wait until I chose that before deciding what equipment to buy.
That's not a Netgear model number. AC1900 is not a unique Netgear model number. Some devices come with the AC tag, but it is essentially a label that Netgear, and others, attach to hardware to describe wifi speeds.
AC1900 is also a somewhat ancient wifi technology from about five years ago. Does Netgear still sell that stuff?
Just another user.
Message 6 of 11
SaintJulio
Re: New to netgear
LMAO okay what router do you recommend i should get
Message 7 of 11
Guru
Re: New to netgear
I would check out something RAX or maybe a MK MESH system. R series routers aren't being made anymore and will eventually be EoL.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CBR750 Modem | Wifi Router CBR750(v.7) | Switches NG GS105/8 and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
Message 8 of 11
SaintJulio
Re: New to netgear
Got you thanks bro
Message 9 of 11
Guru
Re: New to netgear
Message 10 of 11
Re: New to netgear
I would never recommend anything without knowing what you need. We don't all live at the bleeding edge
Go for the cheapest that fills the bill and meets your budget.
Try plugging your needs into the filters on the product pages:
Wireless Routers for Home | NETGEAR
and
Orbi: Whole Home WiFi System for Better WiFi Everywhere | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
Just another user.
Message 11 of 11
Discussion stats
  • 10 replies
  • 237 views
  • 5 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
