Reply
Nighhawk AC1900 Power Light Amber, two other white lights won't access the internet.
awillford
This morning while using wifi everything went dark. The router was not working. I reset the router and modum several times. I've tried hard resetting the Router mulitple times all with the same result.
the power light is a solid amber, Guest wifi is white and wifi on/off is white. I can plug a device in and the port will light up but no internet. I've confirmed with my ISP that the internet is working and I can plug directly inot the Modum and successfully access the internet.
I'm not sure what else to do. Everything I've read says solid amber and hard resetting not working is a hardware issue or corrupt firmware.
Model: R6900P|Nighthawk Smart WiFi Router with MU-MIMO
Message 1 of 7
Re: Nighhawk AC1900 Power Light Amber, two other white lights won't access the internet.
There is the answer. Broken firmware.
If you cannot rescue it with a recovery reset:
  • Press reset for 30 seconds
  • Keep pressing reset while removing power
  • Keep pressing reset for another 30 seconds while apply power
Then you may be reduced to trying TFTP:
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 7
microchip8
Master
And next time, turn off Automatic Firmware Updates. Always do it manually on a wired PC
Routing: NETGEAR R7800 - Voxel Firmware 1.0.2.85SF & Kamoj addon
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400 - Cruncher: Intel Core i5-7400
Message 3 of 7
awillford
Thank you, I'm afraid that might be above my ability but I will give it a try. I will turn off auto-updates I never thought it would cause this issue.
I'm having trouble pinging the router when I plug my laptop into it - I'm not sure what the IP address is so I was just trying everything I found on the web. thoughts?
Message 4 of 7
microchip8
Master
The router's own address is http://192.168.1.1
also check on your computer if you get an IP address from the router. If not, you can't reach it
disabling auto update is in the Advanced administraction -> firmware upgrade
Message 5 of 7
awillford
You're saying, hook the ethernet cable to my computer and then one of the ports on the router? Run the comand Ping 192.168.1.1?
Message 6 of 7
You might find it useful to throw a question at Google:
Google Search – how to unbrick a router
If you can find a video, it can help guide you through the process.
It isn't a straightforward process, but it can save you the cost of a new router.
Just another user.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 709 views
  • 0 kudos
  • 3 in conversation
Announcements
