Reply
Night Hawk AC1900 smart router
ce53
Can someone tell me if this router will work with NordVPN as a server?
Model: R6900|Nighthawk AC1900 Smart WiFi Router
Message 1 of 5
Re: Night Hawk AC1900 smart router
Until a real expert steps in, two suggestions.
Did you search this forum for NordVPN?
Have you asked NordVPN if it maintains a list of supported routers?
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 5
ce53
yes, I checked with nordVPN and on their web page it stated that your router had to support one of these connection types; PPTP, L2TP OR OpenVPN. Futhermore it has to support it as a "Client" ( as opposed to a "server" to allow you to connect it to NordVPN servers.
This is what I need an answer for? Hope you can help me!
thanks
Message 3 of 5
Now that you know the specifications, maybe you could check the manual.
Your subjects says "AC1900", that isn't a Netgear model, so I assume that the R6900 in the footer is what you own.
There is support stuff for the R6900 at the end of this link:
>>> R6900 | Product | Support | NETGEAR <<<
Just another user.
Message 4 of 5
ce53
Thanks for your reply!
Yes i checked on the NordVPN web help page, however no where does it say if it supports as a "client" verses as a "server" in oderd to connect to NordVPN. I have read all the infroamtion on the help site!
Hope you can help.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 416 views
  • 0 kudos
  • 2 in conversation
Announcements
