Orbi WiFi 7 RBE973
Reply
Night Hawk R7000P - 5GHz does not work
hs100
Posted this earlier and upgraded firmware to V1.3.1.44_10.1.23, still no luck.
5GHz radio is enabled but LED stays solid and there's the red X against it in the status page.
SSID broadcast is enabled but doesn't show up in the SSID list.
Laptop and phones both support 5GHz.
Model: R7000P|Nighthawk AC2300 Smart WiFi Router with MU-MIMO
Message 1 of 6
Accepted Solutions
Re: Night Hawk R7000P - 5GHz does not work
i sent mine back in the end. it died again ! got a replacement its fine so far fingers crossed
Model: R7800|Nighthawk X4S AC2600 WiFi Router
Message 6 of 6
All Replies
Message 2 of 6
hs100
I tried enabling Guest WiFi on 5GHz and it didn't work, but thank you for responding.
Hope it gets fixed in a future release.
Message 3 of 6
i should have said disable main 5ghz, then reboot then enable guest wifi, then enable main wifi then turn off 5ghz.
chromecast seemed to cause the dropout of 5ghz for me.....
Message 4 of 6
hs100
That didn't work either 😞
Message 5 of 6
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2993 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
