Reply
Night Hawk R7000P SSID for guest and main domains
river164
I have a Nighthawk AC2300 Smart WiFi Router Model # R7000P. I have 2 SSID problems:
1. I can only connect to the guest network when the SSID is broadcasted. I don't want it to be broadcasted and am wondering why I am having this problem.
2. When I hit "apply" under my wireless settings, this message pops up:
             WPS requires SSID broadcasting in order to work. If you make this change, WPS will
             become inaccessible
Again, I don't want the SSID to broadcast and I don't know what WPS is because it is WPA2 security.
Thanks!
Message 1 of 3
antinode
Guru
Re: Night Hawk R7000P SSID for guest and main domains
>       this change, WPS will become inaccessible
> [...] I don't know what WPS is because it is WPA2 security.
   You may be confusing WPS with WPA.  Visit http://netgear.com/support
, put in your model number, and look for Documentation.  Get the User
Manual.  Look for "WPS" and/or "WPA".
      https://en.wikipedia.org/wiki/Wi-Fi_Protected_Access
      https://en.wikipedia.org/wiki/Wi-Fi_Protected_Setup
Message 2 of 3
river164
Thank you for the advice. I looked up the manual and WPS is "Wi-Fi Protected Setup" and allows you to connect to the WIFI without entering a password. I guess that answered my second question, but I still don't understand why I can't connect to the guest network unless the SSID is broadcasted. The user manual encourages you to broadcast the SSID, but I would prefer not to and it doesn't give any insight as to why it might not be connecting.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 408 views
  • 0 kudos
  • 2 in conversation
Announcements
