- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NightHawk App and 2 Routers (R6700 & D7000). How to Connect to them Remotely
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have added the Nighthawk app to my iphone 8. I have been able to set and access the R6700 which is our primary residence. The D7000 is being used in a second residence to control lighting, heating etc. At times the D7000 seems to stall, thus cutting off control to thermostat. Thus I would like to add the D7000 to the nighthawk app to be able to remotely reset the router. However can not find instructions how to deal with a second router on the nighthawk app.
I also have a Macbook Pro on which I have the Netgear app, which I can use either at primary residence or at secondary residence
Any suggestions how to process so I can add the a second router to the NH app?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is not possible at this time but I have brought it up to the engineers and they are looking into this feature.
DarrenM
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NightHawk App and 2 Routers (R6700 & D7000). How to Connect to them Remotely
Thanks for the clarity on this matter. Will stop looking for a solution that does not exist at this time.
V Smith
