Reply
NightHawk D7000 modem router & Mesh extender
James_M
I am thinking of adding a NightHawk Mesh unit to our network and wondered how a 3 band unit would work with a 2 band router/modem
Message 1 of 4
DarrenM
Sr. NETGEAR Moderator
Re: NightHawk D7000 modem router & Mesh extender
Hello James_m if you are talking about our Mesh extenders then the 3rd band is a dedicated backhaul to make a connection to the router you would only have 2 bands to connect your devices to.
DarrenM
Message 2 of 4
James_M
DarrenM
Many thanks for the reply.
Does that mean that the router would only have one band available to support wifi or would all wifi be through the extender only?
James_M
Message 3 of 4
DarrenM
no the router would work like normal the dedicated band on the extender gives it a better connection and helps it get more speed.
DarrenM
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 973 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
