- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NightHawk R7000 Router page inaccessible
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
This is a brand new router outta the box! & am not able to login or access the Router's pageon my Desktop! My Default gateway (ipconfig) is 192.168.1.1!
steps that I treid
1.) 192.168.1.1 , 10.0.0.1, routerlogin.net all three are inaccessible!
2.) the router connects fine via wireless, I can access the login page from my phone with 192.168.1.1!
3.) I can access it from my Laptop Wired/WIreless! 192.168.1.1!
4.) Hard reset .... nothing helped.
5.) to isolate the issue, I tried with different cables & another router & they just connect fine.
Help appreciated 🙂
Thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
try adding routerlogin.net and Gateway IP in trusted zone or sites. So it will never block going forward.
By way did you tried on the new beta firmware , its fast and has few improved features
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NightHawk R7000 Router page inaccessible
You can't login on to the router? Have you tried to connect to the default SSID and passphrase provided with the router? If you do an ipconfig /all does your laptop or desktop get an IP Address from the router when connecting with an ethernet cable??
The other router is disconnected?
Have you tried clearing your browser's cache?
Have you tried another ethernet port?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try disabling any firewall on your Desktop.
If you can access the router on your phone and laptop then definitely not a router issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, Uninstallating the AnitVirus worekd(Kaspersky Internet Security 2015), now am able to access the router page!
any work around for this?
Thank you very much 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey,
I uninstalled Kaspersky(trail) on Bitdefender now, its not blocking! & am on the factory shipped firmware[V1.0.3.56_1.1.25], will try the recent firmware now 🙂
just one question... Why would a Antivirus program block a simple router page? I've Kaspersky installed on my brother's laptop & Asus router with 192.168.1.1 works fine!
Thanks for the help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @hector1990,
Welcome to Community!
The Anti-virus might be too strict. It blocks the page as it is not using any certificate since it is only offline or only uses HTTP. This depends on the anti virus on how it sees the page.
JamesGL
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good job @hector1990 !!! glad it is now working...... 🙂
