- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NightHawk R7800 upload speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey all i currently just got my HFC NBN installed yesturday and im with optus
i have just added my nighthawk X4s R7800 router onto my net work and after some changes im getting my full
download speed but my upload speed it still limited to 2mbps instead of around 20mbps i have the latest firmware and
have my QOS turned off any ideas??
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
do you get the same if you use another speed test site? If you do, then I'm out of ideas.
if you modem is a Gateway (modem+router) you need to set it in Bridge mode and use the R7800 as router
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NightHawk R7800 upload speed
what is "the latest" firmware? version number is more clear than "the latest"
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey sorry i am currently running 1.0.2.62
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is not the latest firmware for the R7800, which is 1.0.2.62
Are you sure you have an R7800?
- Mark as New
- Bookmark
- Subscribe
- Permalink
god dam it i ment 1.0.2.62 was typing in a rush haha
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try a factory reset and manual reconfiguration. There are quite a few changes between .58 and .62 firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
okay will give that a try after dinner ya i got all the download right just fine with disabling QOS but uploads got me so lost ill get back to you soon
- Mark as New
- Bookmark
- Subscribe
- Permalink
factory reset is that just the little button on back of router??
- Mark as New
- Bookmark
- Subscribe
- Permalink
Okay i did a reset and without the nighthawk im on 54mbps down and 18mbps up on the nighthawk im on 50mbps and up 4.27mbps still runing no qos and on 1.0.2.62
- Mark as New
- Bookmark
- Subscribe
- Permalink
you need to push in the hole at the back until the power LED starts to flash
Alternatively, you can use the WebGUI 192.168.1.1 and go to Advanced -> Administration -> Backup Settings. There's an option to revert to default values with an "Erase" button
- Mark as New
- Bookmark
- Subscribe
- Permalink
okay did it by the erase and still no luck getting 92.91 down and 4.83 up 😞
- Mark as New
- Bookmark
- Subscribe
- Permalink
how are you testing? wired or wireless? If wireless you may need to "forget" the SSID and connect again to it
- Mark as New
- Bookmark
- Subscribe
- Permalink
testing it via wired and use speedtest.net
- Mark as New
- Bookmark
- Subscribe
- Permalink
Should i just be running it in router mode, AP or bridge mode??
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just setting to bridge mode now and will let u know
- Mark as New
- Bookmark
- Subscribe
- Permalink
legend 😄 92.23mbps down and 18.13mbps Up after changing to bridge mode
- Mark as New
- Bookmark
- Subscribe
- Permalink
im i doing right by my HFC cable goes into the arris modem then WAN out of there to the optus box then port 1 out of there to my R7800
or can i get away without the optus box in the middle??
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't know, try it. I suspect your Gateway in Bridge mode connected directly to the R7800 WAN port will work
- Mark as New
- Bookmark
- Subscribe
- Permalink
okay thanks ya its running atm maybe one day ill try removing and try running straight off the Arris NBN modem
