Reply
Nighthawk 6700 V3 keeps dropping wifi
vikadik
My wifi router keeps dropping.
I have tried to do the following
1. Restart both modem and router ( internet is available through wire from router)
2. restart only modem  ( internet is available through wire from router)
3. Factory reset
4. downgrade firmware to following
-R6700v3-V1.0.4.78_10.0.55
-R6700v3-V1.0.4.82_10.0.57
-R6700v3-V1.0.4.84_10.0.58
Still have the same problem.
Any solutions?
Thanks,
-Vikram
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 5
Guru
Re: Nighthawk 6700 V3 keeps dropping wifi
after you downgraded firmware, did you try a factory reset to clear out old/new settings that can cause issues?
The only other firmware I'd try would be the 1.0.3.66 firmware. it was the version prior to netgear armor.
Current setup: CAX80->Trendnet TEG-S380->GS716T-> RBK752->pi-hole
1.4gig download/50mbps upload
We’re members of the public helping out on our own time.
Message 2 of 5
Mikeglad
Keeps dropping off and on?
3. Factory reset
Any solutions?
Thanks,
-Vikram
Message 3 of 5
vikadik
Yep it was dropping, now it does not even start up.
Message 4 of 5
Guru
what are the led's on it showing?
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 500 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
