- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk 6900 Smart Connect Broke With Update
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
wrote:
Hello, I installed firmware update V1.3.0.20_10.1.1 and smart connect no longer works.
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
You can reduce the hassle of reconfiguring all those settings by creating a backup of your settings before you reset. Then if something is still broken after the reset, and the new firmware has not fixed it, you can restore the device to its pre-reset state.
You could even try restoring the settings even if the new firmware has fixed the problems, but be prepared for the restore to also bring back your problems.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk 6900 Smart Connect Broke With Update
I reset it to factory and it fixed the issue. The 5Ghz compatible devices are now on 5Ghz. Still waiting to see if devices get dropped or not. Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's good. Another one rescued by a factory reset.
Fingers crossed that it sticks.
