- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk 7000 responding to port 42443
- Mark as New
- Bookmark
- Subscribe
- Permalink
my nighthawk is responding to port 42443 connection.
I dont know what that is.
When I tried to port forward - had 0 effect.
When I tried to BLOCK the port - the router said I cannot as its being used.
What is this PORT??? how do I disable it?
telnet XX.XX.XX.XX 42443
Trying XX.XX.XX.XX...
Connected to XX.XX.XX.XX.
Escape character is '^]'.
Connection closed by foreign host.
Its clearly responding to it... Not good...
Some external scanner said I failed the scan due to this port.
I think I have the latest firmware running.
How do I disable this port ?
Thanks,
Jerry
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi All,
Port 42443 is used by the Kwilt feature.
It can be closed by disabling DLNA.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk 7000 responding to port 42443
Do you have any gaming console connected to the router now? Disconnect it then scan again if the port is still open.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I do not have any gaming consoles.
Thanks - anything else ?
Jerry
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
ok I turned that off now. and tried again. still responds. Anything else ?
Turn UPnP On | |
Advertisement Period (in minutes) | |
Advertisement Time to Live (in hops) |
- Mark as New
- Bookmark
- Subscribe
- Permalink
did you reboot router after disabling? In the portmap table it should list IP of device requesting the port find it and start looking at that device it's not a router problem something on your network is requesting it.
do you use itunes?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did reboot. Just tried again also. still responding...
I am not finding the portmap table. Where is that ?
All I see is port forwarding.
I do not use itunes. I dont see a setting for that like the uPNP.
Thanks,
Jerry
- Mark as New
- Bookmark
- Subscribe
- Permalink
@JerryGeis66 wrote:
I am not finding the portmap table. Where is that ? All I see is port forwarding.
It's on same page as UPNP
Try a factory default reset
- Mark as New
- Bookmark
- Subscribe
- Permalink
Appears as though my portmap table is EMPTY (see below).
I also looked in the admin logs and I see nothing there about port 42443.
I cannot do a factory reset right now as its in use.
Anything else ?
jerry
Turn UPnP On | |||||
Advertisement Period (in minutes) | |||||
Advertisement Time to Live (in hops) | |||||
UPnP Portmap Table | |||||
- Mark as New
- Bookmark
- Subscribe
- Permalink
What are you looking at to tell that it's still responding
- Mark as New
- Bookmark
- Subscribe
- Permalink
I do a "telnet XX.xx.XX.XX 42443"
and it answers
if I do port 42444 I get no connection
The reason this came up was that for a reason a company scanned my IP and
said this port is responding and flagged it as bad.
Thanks
Jerry
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have reset my unit.
I also checked my other unit. Both are responding to port 42443.
What is this port and how do I disable it.
Jerry
- Mark as New
- Bookmark
- Subscribe
- Permalink
i seem to have it open too, very strange.
can i ask what firmware version you are on? I'm on the latest, so i might try and downgrade to see if it fixes the issue. Dont know what it is but i dont want to leave open
- Mark as New
- Bookmark
- Subscribe
- Permalink
okay i just found out how to disable it. Its the DNLA media server on the router. If you login go to USB Functions > Ready Share Storage > media server tab and then untick the media server option and apply that will close the port
- Mark as New
- Bookmark
- Subscribe
- Permalink
that did it thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes - that worked for me also. THANKS!
jerry
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi All,
