- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk 7800 and 1 gig internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have this router. All cat 6 cables. Just got 1 gig fiber. Speedtest in router service software shows 900+ down and 700+ upload. Actually going to a speedtest and lucky to see 500 down and up never get's past 10.
Latest firmware installed. Did a factory reset to the router. No settings changed except renaming the wirless... but this issue is on wired connections.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, guess Netgear folks are not monitoring, or have no solution.
Will sell off their stuff and find one that actually works.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk 7800 and 1 gig internet
I have a R7800 with the latest firmware (ver 1.0.2.40) and 1 Gbps down and 50 Mbps up cable service. I regularly see 920 Mbps down and 50 Mbps up when running Speedtest.net to my local ISP from a wired Gigabit Ethernet connection at 6:00 am local time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
if i skip the router and go straight to the modem, the speeds are there. That's how I know it's the router slowing things down.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I know how to google search, those items are all off. Now can netgear provide a solution?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your link has NOTHING to do with my question and situation and gear. If you do not have an answer, just say so. I was hoping netgear actually monitored this site to provide support. Perhaps I chose the wrong vender and need to drop them forever. IDK. Seems someone that makes routers would make routers that work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
