- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk 8500 bricked after update
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
You may want to contact support if you are unable to recover the unit via tftp
https://www.netgear.com/support/contact.aspx
DarrenM
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk 8500 bricked after update
> [...] I also tried the windows tftp, I have windows 7, and it seems it
> isn't able to locate the file while trying to put it, [...]
"seems"? Actual command? Actual error message? As usual, showing
actual actions with their actual results (error messages, LED
indicators, ...) can be more helpful than vague descriptions or
interpretations. Copy+paste is your friend.
Which "the file"? Where is the file? What is the current directory?
dir
echo %cd%
If the file is not in your current directory, then you can either move
the file, change your current directory, or else specify a proper path
to the file.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] I currently have the file in a folder in the desktop. To be
> honest I'm not to sure how to change my directory or locate it.
I'd expect your Command Prompt shell program to start up in your
(user-specific) home directory, perhaps something like "C:\Users\fred"
(for a user named "fred"). By default, the Command Prompt program
displays this directory path in its command prompt string
("C:\Users\fred>").
Your Desktop folder would then be "C:\Users\fred\Desktop". To get
there:
cd Desktop
To get to a sub-folder named, say, "Firmware":
cd Firmware
Then a command like the following should work (or, at least, not
complain about not finding the specified file):
tftp -i 192.168.1.1 R8500-V1.0.2.130_1.0.99.chk
Alternatively, starting in "C:\Users\fred", specify a path to the
file (instead of only its leaf name) in your TFTP command. For example:
tftp -i 192.168.1.1 Desktop\Firmware\R8500-V1.0.2.130_1.0.99.chk
A Web search for terms like, say:
windows command prompt directory
should find any number of elementary guides (some better than others, no
doubt). There are many details which may or may not affect you, too,
such as using quotation marks to cope with space characters in
file/directory names. Research as needed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
IP address: 192.168.1.2
Subnet mask: 255.255.255.0
Default gateway: 192.168.1.1
C:\users\jaime\desktop\R8500-V1.0.2.130_1.0.99>tftp -i 192.168.1.2 put R8500-V1.0.2.130_1.0.99.chk
Timeout occurred
Connect request failed
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
DarrenM
