Reply
Nighthawk AC 1900 Wifi Cable Modem Router - A dud ! - Consistently Power Cycling
NNick
>>> Re. Nighthawk AC 1900 Wifi Cable Modem Router Consistently Power Cycling ( a dud!) <<<<
Request for assistance,
My router is periodically power cycling (refers to the act of turning a device or  electronic equipment off, or otherwise disconnecting it from its power source, and then turning it back on again).
I often lose phone calls, WiFI access & web collaboration meeting connectivity when the router power cycles leaving me out in the dark. There’s also a long delay to power back up. This is not only embarrassing but also impacting my business when losing communication with a business partner.
I have tried to reset the modem several tries but it does not solve the issue. The modem is approx. 9 months old.
Is it possible the Netgear brand has become  complete JUNK and  unreliable?  It seems Netgear routers do not even last a year…..
Any recommendation to solve this problem is appreciated.  Netgear support has gone dark with no support!.  Thanks in advance.
Model: C6900|High Speed Cable Modem Router
Message 1 of 4
Re: Nighthawk AC 1900 Wifi Cable Modem Router - A dud ! - Consistently Power Cycling
There is no such thing as a Nighthawk AC1900.
AC1900 is not a Netgear model number. It is a label that Netgear, and others, attach to hardware to describe wifi speeds. Look at the label on the device for the Model.
Your footer says C6900 which is a Cable Modem Router. Is that what you own?
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 4
NNick
Re: Nighthawk AC 1900 MODEL C6900 >> Wifi Cable Modem Router - A dud ! - Consistently Power Cycling
Thanks for the feedback. Yes, the Nighthawk AC 1900 is MODEL C6900.
Any assitance the community can share is appreciated.
Message 3 of 4
You might get better and quicker replies, and find other answers, over in the appropriate section:
Cable Modems & Routers
If it isn't too old, try the warranty return process.
Just another user.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 460 views
  • 0 kudos
  • 2 in conversation
Announcements
