Reply
Nighthawk AC1750 R6400
Froggirl731
my internet went out in the middle of the afternoon.  I went through al the usual reboots and it still did not work.  Showed wifi connection but no internet access.  I call the provider and they walked me through many different steps.  When the modem is connected directly into the desktop the internet works but when it is connected through the router there is no internet connection.  Router is just over a year old.  Provider told me that since the internet works when plugged directly into the desktop that the issue is not with them but with the router.  I have followed all the steps like a new set up and that does not work either.  Any other ideas on how I can get this to work?  I am supposed to be working from home due to the virus but cannot do so without wifi.
Message 1 of 5
microchip8
Master
Re: Nighthawk AC1750 R6400
Have you tried a factory reset?
(also, disable automatic firmware updates option)
Routing: NETGEAR R7800 - Voxel Firmware 1.0.2.88SF & Kamoj addon
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400, 16 TB
Message 2 of 5
Froggirl731
If that is when you use the paperclip on that tiny button yes I have done that a couple of times as well.
Message 3 of 5
antinode
Guru
> [...] R6400
   Is that accurate?  Not R6400v2?  Look at the product label.  Firmware
version?  Connected to what?
> [...] Any other ideas [...]
   Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation.  Get the User Manual.  Read.  Look for the
LED descriptions and "Troubleshoot".
   People here may not be able to see the LEDs on your router.
> [...] I have done that a couple of times as well.
   How, exactly?  Did the LEDs do interesting things?
Message 4 of 5
Guru
What modem are you using?
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 245 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
