Reply
Nighthawk AC1750 R6700 Network map
nlkirchn
Nighthawk AC1750 R6700 firmware V1.2.8_10.0.53 Windows 10 Pro Home network, I am seeing too many wired connections to my router they are unidentified in Genie or the router login. They all start with DEV- and 3 hex numbers separated by colons. It shows 5 wired connections in addition to the correct ones that are identified. The router only has 4 ports for wired devices and I see 8 devices according to Genie and the router login.
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 4
Guru
Re: Nighthawk AC1750 R6700 Network map
What else do you have hooked up to your network?
A network switch?
Wireless extender?
A device running virtual pc's?
NAS running docker with VM's?
You didn't give us much info on the setup of your network or whats running.
the device list isn't always the most accurate with wired/wireless based on how things are hooked into the network.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 4
nlkirchn
I have the following on my network according to the network map:
N AS Wired
Windows PC Dell Wired Through a 4 port hub
Windows PC Dell WiredThrough a 4 port hub
Windows PC HP Wireless
ESP device Wireless
4 Video cameras Wireless
I Phone wireless
I Pad wireless
Brother printer wireless
Video doorbell wireless
Directv HS17 wired
The map shows 4 additional wired connections that are unidentified but all have MAC IDs.
Message 3 of 4
Guru
again, it could be any of those devices too. When I was running freenas, it'd pull a seperate IP and mac for my VM running plex within it.
Easy test? write down the mac, unplug all the devices from the router, shut off the wireless, and reboot. Then slowly hook things back up like switch, computer, etc. When that mac joins again, you can see what on your network it is.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 359 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
