Reply
Nighthawk AC1750 R6700v2
ajarrett151
Follower
I had to do an operating system upgrade on my IMAC and since rebooting, the Nighthawk will not power up.  The wifi light is white but nothing else.  I have powered down everything and restarted.  I have pressed the reset button and nothing is helping.  This router is just over one year old.  Is there anything else that I can do?  Please help
Model: R6700v2|Nighthawk AC1750 Smart WiFi Router
Message 1 of 2
DarrenM
NETGEAR Moderator
Re: Nighthawk AC1750 R6700v2
You will want to hold the reset button for 10+ seconds and if that is not working you may want to contact support.
https://www.netgear.com/support/contact.aspx
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 299 views
  • 0 kudos
  • 2 in conversation
Announcements
