Orbi WiFi 7 RBE973
Reply
Nighthawk AC1750 does run at highest MBPS
NGearUser0000
Our internet service package is 200mbps.  The speedtest shows the router is getting 90mbps.  How can a program the router to get 200mbps?
Model: R6400|AC1750 Smart WiFi Router
Message 1 of 6
Accepted Solutions
Guru
Re: Nighthawk AC1750 does run at highest MBPS
Yes look at the user manual or in the modems web page and check for bridge mode. This is all thats needed. If you can get in to bridge mode then try this, you can still test with the PC connected to the modem or go ahead and connect the other NG router to the bridged modem and test. If your stil not betting full speed either at the modem or with newer router in place and modem bridged, then try testing with different PC as well. If same problem, then you may need to contact your ISP and have them check your line signal up to the modem.
https://www.netgear.com/support/product/C6250.aspx#docs
Message 6 of 6
All Replies
Guru
Are you speed testing wireless or wired LAN cable?
Whats the Mfr and model# of the ISP modem the router is connected too?
Message 2 of 6
NGearUser0000
Netgear AC1600
Model# 1600
mrf 4426237
Message 3 of 6
Guru
Is this the modem?
https://www.netgear.com/home/products/networking/cable-modems-routers/C6250.aspx
If so, then it already had a router built in...
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
Message 4 of 6
NGearUser0000
I plugged the PC directly into the 6250 and it got 60mbps.  Why aren't the modems getting the full 200mbps from the ISP  right out of the box?
The routers are set up this way to take advantage of the ethernet ports to support various devices.  Will the ethernet ports on the 6250 still work when it is in bridge mode?
Would you suggest any threads or websites to get instructions on enabling bridge mode?
Message 5 of 6
Guru
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1161 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
