Orbi WiFi 7 RBE973
Reply
Nighthawk AC1900 Model R7000 troubles
mrsparks1990
Follower
I have been trying for hours using the Virgin SH in modem mode and cat 5 cable from the closest port to the Coax to the red port on the nighthawk.
The wizard will not work and I am not able to navigate to [url]www.roterlogin.net[/url].
But if I put in 10.0.0.1 I can access the interface although it always states network not connected.
It seems to give my PC and ip address 10.0.0.3 but I am not able to surf the web.
If I put the virgin SH in normal mode Iam able to access the wizard via [url]www.routerlogin.net[/url] but the wizard always fails.
Again I get an IP address but am not able to surf the net.
PLEASE HELP
Model: R6900|Nighthawk AC1900 Smart WiFi Router
Message 1 of 3
Accepted Solutions
JamesGL
Master
Re: Nighthawk AC1900 Model R7000 troubles
Hi mrsparks1990,
Disconnect the R7000 from the modem and access routerlogin.
Check the firmware version. Update it if it's not on the latest firmware.
Reset the router.
Message 2 of 3
All Replies
JamesGL
Master
Hi mrsparks1990,
Reset the router.
Message 2 of 3
JamesGL
Master
Hi mrsparks1990,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 4217 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
