Orbi WiFi 7 RBE973
Reply
Nighthawk AC1900 Not Recognizing Signal from Modem
pfene
I recently upgraded my internet to Gigabit service. As a part of the install, the ISP provided a second modem for me to use. Essentially this allows me to either use the Gigabit service or use the 60 Mbps internet I had before. When I use the old modem and the slower service, everything works great (I'm using it now). However, when I use the new modem with the faster service, there is a very fast signal when I plug the Ethernet cable into my computer directly, but the internet light on my router stays amber. So far I have downloaded the latest firmware, reset to factory settings, and reset each individual piece of hardware. The ISP has said that it's a router issue and that I need to go buy a new router. I'm really hoping that's not the case. Any ideas?
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 4
Accepted Solutions
pfene
Re: Nighthawk AC1900 Not Recognizing Signal from Modem
Message 3 of 4
All Replies
Guru
What is the Mfr and model # of both modems?
Cable or Fiber?
Message 2 of 4
pfene
I should have read more before I posted... This worked! Using the computer MAC ID.
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Nighthawk-AC1900-Model-R7000-Won-t-connect-t...
Message 3 of 4
Guru
Glad you got it working. Enjoy.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 6375 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
