Reply
Nighthawk AC1900 R6900v2 firmware
Eam_Mpm
My router needs updated but everytime I try to download the file to update it, it downloads it as a "zip" and I need it in img. format. How can I fix this? It's a R6900v2 Nighthawk AC1900 smart wifi router.
Model: R6900v2|Nighthawk AC1900 Smart WiFi Router
Message 1 of 3
William10a
Master
Re: Nighthawk AC1900 R6900v2 firmware
You need to unzip the file the needed format will be there there are many programs to unzip a zip file, just run one of them on your computer sorry can't tell one to use. I don't know the type of computer you have or its OS you have.
Message 2 of 3
Eam_Mpm
Okay , I finally got it updated but it still won't connect or produce Wi-Fi . I'm seriously at my wits end with this thing .
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 508 views
  • 0 kudos
  • 2 in conversation
Announcements
