Reply
Nighthawk AC1900 R7000 Download Slow
des2016
Follower
For about a week, wireless download speeds dropped from 80Mbps to less than 10 with a Windows 10, iPad Pro and Pixel XL Android 7.  Upload speeds have not changed from the max that Comcast allows at about 12.  Comcast blames the router.  The laptop does not have a LAN port, so I have not tested wired download speeds.
I have tried several older router firmwares and router resets without improvement.  I plan on buying a USB adapter with a LAN connection to physically connect the router to the laptop to test wired downloads.
Any suggestions?
Thanks.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 3
Accepted Solutions
JamesGL
Master
Re: Nighthawk AC1900 R7000 Download Slow
Hi des2016,
You have to check your modem if it is giving the exact speed from your ISP.
Message 2 of 3
All Replies
JamesGL
Master
Hi des2016,
Message 2 of 3
JamesGL
Master
Hi des2016,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3006 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
