- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk AC1900 R7000 login issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm trying to login to routerlogin.net (which I could successfully a month ago). I've not changed the default user name or password. It takes me to the router recovery password screen, to which I input the serial number. The 'continue' button is grayed, so that I can only select 'cancel'. Is there another way to reset the password??
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
so.. looks like reset to factory default then.. http://www.downloads.netgear.com/files/GDC/R7000/R7000_UM.pdf - top of Page 194.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk AC1900 R7000 login issues
The only other way is to reset the router to factory default.. Have you tried the default usenrame and password?" (admin - password).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes - entering 'admin' and 'password' so many times just takes me to the router password recovery screen.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
That worked. Thanks for your help!
