Reply
Highlighted
Follower
Nighthawk AC1900 R7000
Hello, how do I find the DD-WRT firmware to make my NightHawk AC1900 Smart WiFi Router VPN-Compatible.   Please explain how I can install the firmware.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 2
Highlighted
Guru
Re: Nighthawk AC1900 R7000
It's not too hard to Google for dd-wrt r7000.  DD-WRT is not for the casual user.  You really should bone up by visiting the forums at dd-wrt.com.
Note: There are other third-party firmware options for the R7000.  Tomato, Advanced Tomato and AsusWRT, to name a few.
Second Note: Stock firmware has built-in VPN server support.  You'll only need third party firmware if you need VPN client support.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2723 views
  • 0 kudos
  • 2 in conversation
Announcements
