MitchZ
Dec 11, 2020Follower
Nighthawk AC1900 compatibility with Gryphon Guardian Mesh WiFi System
Will the Gryphon Guardian 3 pack mesh WiFi router work with this Netgear product
1 Reply
MitchZ wrote:
Will the Gryphon Guardian 3 pack mesh WiFi router work with this Netgear productWhat Netgear product? Work how?
AC1900 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Is the Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0 listed in your footer involved in this in anyway? Or did you just click the first thing that popped up when you wrote your message?
