Orbi WiFi 7 RBE973
Reply
Nighthawk AC2300 R700p open vpn configuration
Gtfox
Follower
I am trying to configure Open VPN.  Have followed all instructions.  when I try to connect I get the following error messages;
OpenSSL: error:140AB18E:SSL routines:SSL_CTX_use_certificate:ca md too weak
 Cannot load certificate file client.crt
client
dev tap
proto udp
sndbuf 393216
rcvbuf 393216
push "sndbuf 393216"
push "rcvbuf 393216"
dev-node NETGEAR-VPN
remote Gary-PC.mynetgear.com 12974
resolv-retry infinite
nobind
persist-key
persist-tun
remote-cert-tls server
ca ca.crt
cert client.crt
key client.key
cipher AES-128-CBC
comp-lzo
verb 0
What is the solution?
Thanks
Message 1 of 3
Accepted Solutions
JamesGL
Master
Re: Nighthawk AC2300 R700p open vpn configuration
Message 2 of 3
All Replies
JamesGL
Master
Message 2 of 3
JamesGL
Master
Hi Gtfox,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2940 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
