Orbi WiFi 7 RBE973
Reply
Nighthawk AC2300 firmware update fails
Toi-Gye
Initiate
I connected to the router through a pc to update the firmware. after the router had downloaded the latest update, it started installing and rebooting. but now only the power light flashes and I do not get access to the router.
It does not help to press the reset button. Nothing happens.
please help.
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 4
Accepted Solutions
Guru
Re: Nighthawk AC2300 firmware update fails
Sounds like something must have happened during the update.
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Message 2 of 4
All Replies
Guru
Message 2 of 4
Toi-Gye
Initiate
Thank you very much for your help.
It worked after countless attempts.
thanks again.
Message 3 of 4
Guru
Glad to hear it worked!
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1112 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
