Orbi WiFi 7 RBE973
Reply
Nighthawk AC3200 readyshare storage
Calhoun
Guide
I've got a Sabrent USB 3.1 / 3.0 to SATA External Hard Drive Docking Station that I plugged a 2 TB Western Digital Black HDD into the router readyshare USB 3.0 storage slot as an alternative to a ready-made external HDD. It is formatted in ExFat in Windows 10.
The device works fine as a plug and play storage option on the PC, but the router does not detect it. The Sabrent dock says that no drivers are required, as it is plug and play and only provides power and a place to hold the HDD.
Anyone got any ideas? Maybe format NTFS or something? Thanks!
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 3
Accepted Solutions
storm1985
Prodigy
Re: Nighthawk AC3200 readyshare storage
yep try NTFS i dont think exfat is supported.
Message 2 of 3
All Replies
storm1985
Prodigy
Message 2 of 3
Calhoun
Guide
Yep, that worked. Thanks, buddy!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3343 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
