× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Nighthawk® AX12 RAX120 5GHz Issues
bcuziwasbored
I just got the RAX120, but when I went to set it up, I found that I can't see the 5GHz band from any of my devices. I have multiple devices which support WiFi 6, but they can't see it either. I've checked that it is broadcasting and tried changing channels and modes, but I haven't had any luck. Does anyone have any recommendations? I purchased this from Amazon Warehouse, so I can get a refund, but not a replacement. I'd really appreciate any help -- thanks in advance!
Here are the 5GHz settings:
Channel149(P)+153+157+161
ModeUp to 4333 Mbps(80MHz)
Wireless APOn
Broadcast NameOn
Here's my model number and firmware version as well.
Hardware VersionRAX120
Firmware VersionV1.0.1.118
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 5
Accepted Solutions
bcuziwasbored
Re: Nighthawk® AX12 RAX120 5GHz Issues
Amazon Warehouse got another unit last night. I'm just going to get a replacement. Thanks for your help though!
Message 5 of 5
All Replies
Christian_R
NETGEAR Employee Retired
Hello bcuziwasbored,
Would you mind performing a factory reset to see if that would help. You may also try to get in contact with our support team as newly purchased devices are provided with complimentary support.
https://www.netgear.com/support/default.aspx
Christian
Message 2 of 5
bcuziwasbored
I factory reset it twice, but that didn't make a difference. I got it from Amazon warehouse, so it's basically refurbished. It was previously linked to someone else's account, so the 90 days is support has ended.
Message 3 of 5
Hey bcuziwasbored,
Check what you have enable at the top of wireless setting.
Also, I don't have a mode of 4333.
If you can I will conpare my setting with yours but you need to tell all of them which could be pain full. If you can tell my all of the Wireless ones.
Shelby500GT.
Message 4 of 5
bcuziwasbored
Message 5 of 5
Discussion stats
  • 4 replies
  • 3023 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
