- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk AX6000 compatible with Nighthawk Dual-Band WiFi 6 Mesh System 1.8Gbps Router + 2 Satellite
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk AX6000 compatible with Nighthawk Dual-Band WiFi 6 Mesh System 1.8Gbps Router + 2 Satel
You can do that but it wouldn't 'integrate' with the system.
What actual router do you have? AX6000 is a speed, not a model.
Before investing more in mesh systems, I'd look at getting either ethernet pulled or using moca adapters for a backhaul. Reason why is the mesh system still need a wireless connection between them. If your home is struggling because of interference and not from size, switching to a mesh doesn't always help. It can help but usually you need to figure out a better link between the satellites/router or its going to have the same issues your having now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your response, the model I'm using is an RAX80, been very good but as I mentioned signal isn't always good enough in some parts of the house. I was hoping to add some sort of nest or perhaps run an ethernet cable to another device but no idea what tbh?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It won't integrate but you can pair it with a mesh system. Especially if you can hardwire it in.
If its not hardwired, you just need to keep in mind that if your devices don't have a good signal in a location, neither will the satellites.
- Mark as New
- Bookmark
- Subscribe
- Permalink
