mike1213
Dec 20, 2020Aspirant
Nighthawk AX8 Port Aggregation with my QNAP NAS
Hi all
I setup port aggregation on my AX8 Router to "Enable (LACP-IEEE 802.3ad)"
In my QNAP NAS, it shows NIC1 and 2 are teamed in 802.3ad "dynamic" mode and that it's getting a working connection.
Not sure where came wrong that it is showing "Ethernet Port Aggregation Status: Inactive" in NETGEAR WEB UI.
thanks you for your help.
1 Reply
- Christian_RNETGEAR Employee Retired
Hello mike1213,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
