Orbi WiFi 7 RBE973
Reply
Nighthawk AX8 firmware update wifi issues
sliepa
So I complete a firmware update yesterday and now the system can't recognise the 2.4 and 5 G wifi.
I also have many smart devices connected and now they don't connect properly.
I see a new smart setting which will allocate devices to which wifi they will connect to but this does not work either.
firmware version V1.0.5.126
APP version2.10.5.17
Any ideas as I can't get support from Netgear.
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 6
Guru
Re: Nighthawk AX8 firmware update wifi issues
What actual router do you have? (look on the label)
Anytime theres an issue after a firmware change, the first thing I'd try would be a factory reset and reinstall. sometimes the firmware can change enough that an old setting can cause issues.
Message 2 of 6
ArmoredBear1771
Initiate
 Mine autoupdated yesterday and disconnected me from my netgear router which i use for gaming. my spectrum router works fine but the nighthawk app wont connect because it say my netgear router is disconnected. i bridged the nighthawk router months ago because i was getting double nat issues and that fixed it but now it seems like its not supported anymore from what i could find. All in all i just want this issue to be fixed.
Model: RAX40|Nighthawk AX4 4-Stream WiFi Router
Message 3 of 6
sliepa
My model is RAX80 (AX6000). Thanks very much. I will try this but will it try to update the firmware to the most current version?
Message 4 of 6
Guru
A factory reset doesn't change firmware. It only clears out the settings.
Message 5 of 6
Try checking the section given over to your device:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
That's where RAX80 users hang out.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1252 views
  • 2 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
