- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk App (formerly up)
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just downloaded the app on my smartphone and upon installation and setup it says my Nighthawk router is not compatible (R7500v2).
What is the problem?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here is the list of supported routers but we are constantly updating.
https://kb.netgear.com/000055505/Which-routers-support-the-NETGEAR-Nighthawk-app
DarrenM
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk App (formerly up)
- Mark as New
- Bookmark
- Subscribe
- Permalink
The r7500v2 was recently updated to Firmware Version 1.0.3.36. The change logs says that this update allows the router to work with the app.
I think Netgear needs to update the app in order to support the router because I'm having the same issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you! That completely answers the question. My Nightawk AC2350 router R7500v2 is not on the compatability list for the Nighthawk App.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@eguerbox wrote:
Hi,
Perfectly correct - https://kb.netgear.com/000059531/R7500v2-Firmware-Version-1-0-3-36 release notes state
New Features and Enhancements:
- Supports the Nighthawk app version 2.1
And (for example) the Android version of the Nighthawk App is on some v2.2 for a while already.
@DarrenM ... what gives?
@AbhayB ... more problems, still one big mess, isn't it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I will double check what is going on with this.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yeah.. i have the same prob. the newer frimware update logs says it has support for new app but it doesnt.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
This was a mistake in the firmware notes but support for this router is coming soon.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Similar problem with the XR450 - all docs does claiming it's supported, however similar message. Disappointing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Nighthawk app on my iphone stats the XR450 is not supported.
I just purchased the XR450 on Saturday, installed and registed the device last night, and am not able to contact support. The GUI on a laptop is really nice, not so nice on the smartphone safari browswer, so I hope the app will be updated so I can use it on my mobile device.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well u do have to use Netgear Genie app from the app store becuse R7500v2 doesn't support Nighthawk(Fromaly Up) app as of now. Netgear Genie app is available for ios,android and windows. thats what i use.
