Reply
Nighthawk C7000 Cable Modem Router and R7000 Smart Wifi Router
tayloma4
I just purchased a AC1900 Wifi Cable Modem Router model number C7000.  I have a fairly large house and I want to extend my wifi signal.  Can I use the AC1900 Smart Wifi Router model number R7000 for this?  My intent is to connect the two via an ethernet cable.  I would then also connect a Playstation PS3 to the R7000 router via an ethernet cable also.  Not sure if this is the way to do this or not.  Am I doing this correctly or is there a different setup I could use?
Thanks for your help..
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 6
Accepted Solutions
ElaineM
NETGEAR Employee Retired
Re: Nighthawk C7000 Cable Modem Router and R7000 Smart Wifi Router
Welcome to the community, @tayloma4
Yes, you can connect the two together with an Ethernet cable.
But first you need to configure the R7000 to act as an Access Point.
You may see the link below on how to configure the R7000 in Access Point mode.
How do I change my Nighthawk router to AP mode after I’ve already run setup?
ElaineM
NETGEAR Community Team
Message 2 of 6
All Replies
ElaineM
ElaineM
Message 2 of 6
tayloma4
Thank you @ElaineM!  Seems pretty straight forward.  I'll give it a shot.
Michael
Message 3 of 6
ElaineM
You're very welcome.
Keep us updated!
ElaineM
Message 4 of 6
tayloma4
Got it all set up and it works great! Thanks for your help.
Message 5 of 6
ElaineM
That's great!
ElaineM
Message 6 of 6
Discussion stats
  • 5 replies
  • 3560 views
  • 0 kudos
  • 2 in conversation
Announcements
