× Some paid Circle Parental controls customers may be showing free options only. Router firmware correcting this issue will be available ASAP. Visit Status.NETGEAR.com for updates.
Discussion stats
  • 1 reply
  • 259 views
  • 0 kudos
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
Follower
Nighthawk D7000v2 Firmware update issue(does not updating)
I have recently buy this model and has many probles like keeps droping wifi connection radomly during the day anyone know any solution?
2) While try to update firmware it says 1.0.0.45 available but when i try to upgrade it successfully reboots but when i enter root login gateway page it says its still has the old version of firmware and a NEW firmware is availaible but it makes no sense because i already upgrade it ...i Tried manual updating to this firmware but still the same problem persist......i also tried reset but still doesnt work.... any solution? is maybe a good time to return back the router/modem?
Message 1 of 2
Highlighted
Re: Nighthawk D7000v2 Firmware update issue(does not updating)
You are not alone. A known issue:
Re: D7000v2 firmware update v1.0.0.45 will NOT ins... - Page 2 - NETGEAR Communities
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
