Reply
Nighthawk Internet Port not working
LeeJay
I am unable to access the internet using my NETGEAR Nighthawk R700 router. It appears that the internet port is not working because when trying to setup the router I am getting the following message: "No Ethernet Cable is plugged into the Router Internet Port" even though an Ethernet cable is connected. In fact, I tried multiple cables. In addition, the modem doesn't indicate that a device is connected when using the R7000 but for other devices it does. I tried resetting the modem several times but that didnt help.
I would appreciate some advice. Thanks.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 2
Re: Nighthawk Internet Port not working
Duplicate post:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Nighthawk-AC1900-Internet-Port-not-working/m...
~Comcast 1 Gbps/50 Mbps SB8200 > R8000P
~R8000P FW:1.4.1.68 ~R7000 FW:1.0.9.42
~R6400 FW:1.0.1.52 ~Orbi-AC3000 FW:2.5.1.8
~EX3700 FW:1.0.0.84
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2014 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
