- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk M1 intermittently disconnects from the internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have 2 Nighthawk M1 Hotspot Routers, both using ATT SIM cards for data. Both are plugged in without batteries installed. One has worked perfectly for over a year, the other (recently purchased) will not stay connected to the internet. It turns off in the middle of movies on Netflix, etc. I have to physically go hold the button down to turn the wifi back on. What gives?
I saw another post with the same problem, but I couldn't understand the solution. It said something about 'Wifi UI'. What is a UI? I'm not techie, so please explain in lay terms and if a website is needed, please show which website to access. Thank you for any assistance as this is an annoying problem for a relatively expensive item.
