× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Nighthawk M2 wifi not working
Chainsawkid
Hi. My M2 wifi just stopped working.
It has an X through the wifi icon. I didn’t change any settings.
I have factory reset it and still not working.
I can’t connect it to my computer as I don’t have an Ethernet port.
Please help.
Message 1 of 4
TeeJay74
Virtuoso
Re: Nighthawk M2 wifi not working
You should be able to enable M2 wifi via touchscreen.
Message 2 of 4
Chainsawkid
Nope. It’s all on and factory reset. But I get an x through the wifi icon
Message 3 of 4
Bcanr2d2
I have the same issue, with the most recent firmware update appearing to cause the issue
Firmware version NTGX24_10.17.03.00
I've tried to enable and disable IP Passthrough, as well as enable and disable USB tethering, to force the device to enable the wifi again, but like you I have factory reset to no avail, as the wifi appears to be disabled.
Is there a CLI to change a erroneous setting to get this unit working properly again?
Model: MR2100|Mobiler Router Nighthawk M2
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1546 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
